Originally published at: ZDS: End-to-end IoT Development with Zephyr by Alvaro Viebrantz - Golioth
Founding Engineer of Golioth, Alvaro Viebrantz went to the Zephyr Developer Summit…and said the hardware isn’t the only part of an IoT system that matters. That’s bold! This was a room full of hardware and firmware designers! In reality, this talk is about everything else you should consider when building a device using the Zephyr Real Time Operating System (RTOS). Alvaro goes through the many layers and considerations when architecting large scale Internet of Things (IoT) deployment, from the servers, to the apps, to how devices are communicating back to the cloud, and yes, all the way down to the code put onto the end device. Top Down Design Most IoT users first experience a device not from holding the hardware in their hand and seeing it do some particular action. Instead, users rely on things like Dashboards and Applications. The physical device is often hidden from the end user, at least inside an enclosure, and sometimes entirely (as in the case of something like a home monitor in your attic). It’s important to start by mapping your data model, often before you even start your first schematic. What will your device do? How will it be accessed hierarchically? What other elements are part of the system or will be in the future? Also important, you should follow the ownership of both the physical device and that device’s output data all the way up the chain back to the user. How will a user claim a device belongs to them? How will you organize the various levels of permission required? What kind of questions will your users seek to answer with the end device or with the entire fleet? (ie.…
