I’ve been unable to find my out-of-tree board definitions to Golioth firmware SDK 0.15.0. It will work on the command line but sysbuild fails before reading any of the config files.
–start with reference design template_v2.4.1
–copy aldul_mini in-tree board definition to aldul-mini2 in ./app/board/vendor and patch up all references
–It builds properly with “west build -p -b aludel_mini2/nrf9160/ns --sysbuild app – -DBOARD_ROOT=.” so the board file is good.
jstuewe@Inspiron-3910:~/prj/golioth15$ west build -p -b aludel_mini2/nrf9160/ns --sysbuild app – -DBOARD_ROOT=.
– west build: making build dir /home/jstuewe/prj/golioth15/build pristine
– west build: generating a build system
Loading Zephyr module(s) (Zephyr base): sysbuild_default
– Found Python3: /usr/bin/python3 (found suitable version “3.10.12”, minimum required is “3.8”) found components: Interpreter
– Cache files will be written to: /home/jstuewe/.cache/zephyr
– Found west (found suitable version “1.2.0”, minimum required is “0.14.0”)
– Board: aludel_mini2, qualifiers: nrf9160/ns
Parsing /home/jstuewe/prj/golioth15/deps/zephyr/share/sysbuild/Kconfig
Loaded configuration ‘/home/jstuewe/prj/golioth15/build/_sysbuild/empty.conf’
Merged configuration ‘/home/jstuewe/prj/golioth15/app/sysbuild.conf’
Configuration saved to ‘/home/jstuewe/prj/golioth15/build/zephyr/.config’
Kconfig header saved to ‘/home/jstuewe/prj/golioth15/build/_sysbuild/autoconf.h’
’ * Running CMake for mcuboot *
Loading Zephyr default modules (Zephyr base).
– Application: /home/jstuewe/prj/golioth15/deps/bootloader/mcuboot/boot/zephyr
{… Successful compile}
I’ve tried a dozen ways to set BOARD_ROOT in config files but it appears that sysbuild fails to find the board before reading any of them.
sysbuild has three sections, the initial load, CMake for mcuboot, and CMake for app. The documented method to add BOARD_ROOT using CMakelists.cfg is only valid for the last run, which it never gets to so there has to be a different way to set it.
As you can see below it fails to find the board before it even reads sysbuild.conf, much less CMakelists.txt
No board named ‘aludel_mini2’ found.
What is the method to set custom board paths when using 0.15.0 which moved over to sysbuild? All previous articles and blogs are out of date and don’t work.
