Thousands of ESP32s: Device Management for ESP-IDF based devices
Originally published at: Thousands of ESP32s: Device Management for ESP-IDF based devices - Golioth
DevCon22 was a 2 day event that Espressif held last month to showcase upcoming products from Espressif as well as external partner offerings. Mike and I (Chris), gave a talk about how the Espressif IoT Development Framework (ESP-IDF) makes it really easy to add Golioth to your IoT projects. The ESP32 line of Wi-Fi based devices deliver the internet connection, while the Golioth ESP-IDF SDK provides access to things like: Over-The-Air Updates Time-series Database Stateful Database Settings Service Remote Procedure Calls Cloud Logging Service and more! Golioth covers your hardware Golioth supports multiple hardware ecosystems, and we expect to enable even more in the future! We’ve built everything firmware engineers need to seamlessly connect their devices to the Golioth Cloud. Our goal is to meet engineers where they work, and this often means working directly inside the ecosystems their projects are built upon. We were excited to support the ESP-IDF, which is based off the popular FreeRTOS core. This open source Real Time Operating System (RTOS) is prevalent throughout the electronics industry, with ports into many different chip ecosystems. The Espressif team has taken the core capabilities and ported it to work across their growing catalog of components. They have also bundled a range of meta tools that includes the build system (idf.py), the programmer (esptool.py), and more. The Golioth ESP-IDF SDK leverages the necessary components to immediately access the Golioth Cloud on Espressif devices. We use CoAP as a transport layer, so we include a CoAP library to allow your device to “talk” CoAP. Golioth is secure by default, so we also include an mbedtls library, to allow your packets to be encrypted (using your PSK-ID and PSK). The…
