The Miserable State of Modems and Mobile Network Operators
Originally published at: The Miserable State of Modems and Mobile Network Operators - The Golioth Developer Blog
This is a story of the complexities of cellular connectivity, the perils of closed ecosystems, and how to debug what you cannot see.
An excellent writeup on an issue I’ve seen and reported before. It’s good to see how far Golioth is digging into these very complex issues. So is the medium-term solution to continue setting the secondary DNS manually?
@john.stuewe yes, we would recommend setting the secondary DNS server address manually for the time being. We’ll keep this thread updated as a more robust solution is developed.
Great article - have the same issue with modem_cellular and simcom7080G
It’s been six months. Has there been any progress on a long term solution or should we continue to hard code the secondary DNS?
@john.stuewe thanks for following up! As of sdk-nrf v3.1.0, there is now a CONFIG_LTE_LC_DNS_FALLBACK_MODULE that is enabled by default that will cause a DNS server configured in Zephyr to be used for fallback, or can be overridden with CONFIG_LTE_LC_DNS_FALLBACK_ADDRESS.
