Originally published at: Storing Golioth credentials on the nRF9160 using TLS Tags - Golioth
Nordic’s nRF9160 cellular modem includes a great peripheral called the Key Management Unit (KMU). This secure key storage mechanism lets you write keys to it which cannot be read back. However, they can still be used for DTLS authentication. In this video and blog post I’ll walk you through how to use the feature with the newest release of the Golioth Firmware SDK. Overview of secure storage and TLS Tag authentication With the v0.10.0 release of the Golioth Firmware SDK, credentials may be selected using the TLS secure tag. One example of hardware that embraces this is the Nordic nRF9160, which implements Zephyr’s TLS credential management API. Credentials (either x509 certificates or pre-shared keys) are stored on the device using a security tag. Pass that tag to the Golioth Firmware SDK and enable offloaded DTLS sockets in order to utilize those securely stored secrets. Since these credentials are stored separately from firmware, they are persistent and you can store multiple different credentials. At runtime, pass the security tag as a parameter when creating the Golioth client and you’re all set. How to store credentials on the nRF9160 Storing credentials on the nRF9160 is accomplished in two steps: first generate and prepare the credentials, then place them on the device using AT commands. (Don’t worry, there are helper tools to generate the AT commands for you.) Generating Certificates Golioth has long supported certificate authentication. You can follow the Certificate Authentication guide in our Docs. You will need to use the .pem version of the device certificate and key, and you’ll also need the root certificate from the CA that issued Golioth’s server certificate (we use LetsEncrypt.org). Generate the root certificate and…
