Hi there,
Been testing out pipelines and hacked one of the examples to build an SQS pipeline:
path: "*"
content_type: application/json
steps:
- name: step-0
destination:
type: batch
version: v1
- name: step-1
transformer:
type: extract-timestamp
version: v1
- name: step-2
transformer:
type: inject-path
version: v1
destination:
type: aws-sqs
version: v1
parameters:
url: https://sqs.ap-southeast-2.amazonaws.com/123456789012/Golioth.fifo
access_key: <my_api_key>
access_secret: $AWS_SQS_ACCESS_SECRET
region: ap-southeast-2
- name: step-3
destination:
type: lightdb-stream
version: v1
Note that I have tried this with both my SQS server and the Golioth example. I have also confirmed that $AWS_SQS_ACCESS_SECRET is saved in the secrets manager.
When I run this using the simulator, I never see the message either in AWS, nor LightDB. I do however get two LightDB entries if I replace the SQS destination with a copy of the LightDB destination details, suggesting the SQS portion is failing somewhere, and the pipeline is terminating.
It feels like a pretty trivial example and should be straightforward. It also feels like something is bombing out on the Golioth side.
Any guidance is appreciated!
