Originally published at: Signed URLs for Embedded Devices - The Golioth Developer Blog
Today we are launching support for device signed URLs, which is now available for Golioth projects in Teams or Enterprise tier organizations. The feature is off by default, but can be enabled on the settings page for a project. We are also releasing signy, an open source firmware library for generating signed URLs on embedded devices. Signed URLs Background Signed URLs are typically used on the web to grant time-limited access to private resources. The most common use is with Content Delivery Networks (CDNs), where a client may request a large private media asset from an origin server that is geographically far away, then be redirected to a closer CDN server with a signed URL to speed up the download of the asset. In order to avoid complex authentication and authorization logic across a large, geographically distributed CDN, the origin server can determine whether the client can access the asset, then generate a signed URL that the CDN server is able to verify as issued by the origin. When the client uses the signed URL, the CDN server verifies the signature in the URL, and ensures that the URL is not being used outside of any time restrictions included in URL parameters. Bringing Signed URLs to Embedded Devices While device signed URLs use a similar technique to traditional signed URLs, the device, which would usually be thought of as a client, is acting more like an origin server. But if the device is the origin server, then who is the client? To be more precise, a component on a device is acting like an origin server, and the client may be another component on the same device, or an external…
