Sending JSon sensor data to lightdb stream using pipeline but not displaying on dashboard
Hi all, I’ve been debugging LightDB Stream all day and I’m completely stuck.
Wi-Fi connects and logs show device is online
golioth_lightdb_set_async() works — values show up in LightDB State
But nothing ever shows up in LightDB Stream, even after hours of testing
GOLIOTH_LOG() works — I can see device logs via goliothctl logs listen
Stream publishing returns GOLIOTH_OK — device says rows are being sent
This is the code i am currently using in the golioth_manager.cpp file:
#include “golioth_manager.h”
#include “golioth/client.h”
#include “golioth/lightdb_state.h”
#include “golioth/golioth_status.h”
#include “golioth/golioth_sys.h”
#include “golioth/stream.h”
static struct golioth_client* s_client = nullptr;
static void on_golioth_event(struct golioth_client* /client/,
enum golioth_client_event event,
void* /arg/)
switch (event) {
case GOLIOTH_CLIENT_EVENT_CONNECTED:
ESP_LOGI(“GOLIOTH_MGR”, “connected to Golioth”);
break;
case GOLIOTH_CLIENT_EVENT_DISCONNECTED:
ESP_LOGW(“GOLIOTH_MGR”, “lost Golioth connection”);
break;
default:
ESP_LOGI(“GOLIOTH_MGR”, “event %d”, (int)event);
break;
Helper: build a compile‑time config struct /
static void build_golioth_config(struct golioth_client_config
cfg)
memset(cfg, 0, sizeof(*cfg));
cfg->credentials.auth_type = GOLIOTH_TLS_AUTH_TYPE_PSK;
cfg->credentials.psk.psk_id     = GOLIOTH_PSK_ID;
cfg->credentials.psk.psk_id_len = strlen(GOLIOTH_PSK_ID);
cfg->credentials.psk.psk        = GOLIOTH_PSK;
cfg->credentials.psk.psk_len    = strlen(GOLIOTH_PSK);
void golioth_manager_init(void)
if (s_client) {
ESP_LOGW(TAG, “Golioth already initialised”);
return;
struct golioth_client_config cfg;
build_golioth_config(&cfg);
s_client = golioth_client_create(&cfg);
if (!s_client) {
    ESP_LOGE(TAG, "Failed to create Golioth client (NULL returned)");
    return;                            // avoids NULL‑dereference crash
golioth_client_register_event_callback(s_client, on_golioth_event, nullptr);
ESP_LOGI(TAG, "Golioth client created");
golioth_client_start(s_client);
ESP_LOGI(TAG, "Golioth client started");
bool golioth_is_connected(void)
return s_client &&
(golioth_client_is_connected(s_client) == GOLIOTH_OK);
void golioth_send_sensor_data(void)
if (!golioth_is_connected()) return;
sens_reading_t s;
sensors_get_latest(&s);
uint64_t ts_ms = esp_timer_get_time() / 1000ULL;
//static uint32_t loop = 0;
char json[300];
int n = snprintf(json, sizeof(json),
"\"temp\":%.2f,\"humidity\":%.1f,"
"\"red\":%d,\"green\":%d,\"blue\":%d,\"ir\":%d,"
"\"moist1\":%d,\"moist2\":%d,"
"\"percent\":%d,"
"\"voltage\":%.3f,"
"\"connected\":true,"
"\"timestamp\":%" PRIu64
s.temp, s.humi,
s.red, s.green, s.blue, s.ir,
s.moist1, s.moist2, s.percent,
s.voltage,
ts_ms);
if (n < 0 || n >= sizeof(json)) {
    ESP_LOGW("GOLIOTH_TX", "JSON buffer too small");
    return;
enum golioth_status rc = golioth_stream_set_async(
    s_client,
    "sensor_test",                // root path
    GOLIOTH_CONTENT_TYPE_JSON,
    (const uint8_t*)json,
    strlen(json),
    nullptr, nullptr);
ESP_LOGI("GOLIOTH_TX", "stream row → %s", golioth_status_to_str(rc));
ESP_LOGI("GOLIOTH_PAYLOAD", "sending JSON: %s", json);
The data sent from the device should appear in the LightDB Stream tab
Nothing shows up in LightDB Stream, ever.
Even after multiple successful logs and stream sends (GOLIOTH_OK).
Pipeline is running and assigned to the device, but data seems silently dropped.
This completely blocks our telemetry pipeline.
We can’t visualize or query our device’s historical sensor data — a critical feature for our product.
Device: ESP32-C3
ESP-IDF: v5.1.1
Golioth SDK: golioth-firmware-sdk (latest as of May 2025)
Firmware: Uses golioth_stream_set_async(…) with JSON payload + millisecond timestamps
I (7891) LIGHTDB_TASK: loop 2
I (7891) GOLIOTH_TX: stream row → GOLIOTH_OK
I (7891) GOLIOTH_PAYLOAD: sending JSON: {“temp”:35.50,“humidity”:60.8,“red”:187,“green”:338,“blue”:192,“ir”:120,“moist1”:3817,“moist2”:3818,“percent”:0,“voltage”:0.000,“connected”:true,“timestamp”:7902}
Attempts to Resolve
Confirmed pipeline filter/path matches (sensor_test)
Added “timestamp” field (int64, UNIX ms)
Tried manually sending stream via goliothctl (couldn’t verify due to stream error)
Added logging of payload JSON to confirm structure
Confirmed device is online + assigned to pipeline
I have been able to resolve this.
After realizing that my initial payload was too large, and since this was my first time testing LightDB Stream; I decided to start with a minimal test to better understand how it works with pipelines.
I sent a simple “Hello, World” message through the pipeline and successfully saw it appear on the dashboard. I also followed the documentation on pipelines, which helped me get a better grasp of the setup.
From there, I created a minimal send_temperature_only() helper function and gradually started building on top of that.
