Now that pipelines are defined as *.yml files (which are currently being stored as examples in git repos, e.g. thingy91-golioth/pipelines/cbor-to-lightdb-with-path.yml at main · golioth/thingy91-golioth · GitHub), I was just curious if y’all have thought about something along the lines of “infrastructure as code” for Golioth projects, i.e. as an alternative to copy-paste into the Golioth console.
In the same vein, it would also be nice to be able to populate a project’s “Device Settings” from a config file that’s checked into the project repo (I’ve had typos, or set the wrong data type, etc).
N/A
N/A
N/A
N/A
