I have been following the directions for installing the ESP32 toolchain and hit a roadblock. I have been following the directions on the docs site, but the toolchain is not found. Am I doing something wrong?
Here is the error output from my terminal (linux)
=== downloading ESP-IDF tools..
Installing tools: xtensa-esp32-elf, xtensa-esp32s2-elf, riscv32-esp-elf, openocd-esp32
Skipping [email protected] (already installed)
Skipping [email protected]_64eb9ff-8.4.0 (already installed)
=== downloading ESP-IDF tools completed
The toolchain has been downloaded to /home/maximm/.espressif/tools/zephyr
Export or set the following variables into the environment:
export ESPRESSIF_TOOLCHAIN_PATH="/home/maximm/.espressif/tools/zephyr"
export ZEPHYR_TOOLCHAIN_VARIANT="espressif"
(.venv) maximm@maximm-x1c9:~/zephyr-esp/zephyr$ ^C
(.venv) maximm@maximm-x1c9:~/zephyr-esp/zephyr$ export ESPRESSIF_TOOLCHAIN_PATH="/home/maximm/.espressif/tools/zephyr"
(.venv) maximm@maximm-x1c9:~/zephyr-esp/zephyr$ west build -b esp32 samples/basic/minimal/
-- west build: generating a build system
Including boilerplate (Zephyr base (cached)): /home/maximm/zephyr-esp/zephyr/cmake/app/boilerplate.cmake
-- Application: /home/maximm/zephyr-esp/zephyr/samples/basic/minimal
-- Zephyr version: 2.7.99 (/home/maximm/zephyr-esp/zephyr), build: v2.7.99-2139-g2bf02f4854aa
-- Found west (found suitable version "0.12.0", minimum required is "0.7.1")
-- Board: esp32
-- Cache files will be written to: /home/maximm/.cache/zephyr
-- Using toolchain: zephyr 0.13.2 (/home/maximm/zephyr-sdk)
-- Found dtc: /home/maximm/zephyr-sdk/sysroots/x86_64-pokysdk-linux/usr/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6")
-- Found BOARD.dts: /home/maximm/zephyr-esp/zephyr/boards/xtensa/esp32/esp32.dts
-- Generated zephyr.dts: /home/maximm/zephyr-esp/zephyr/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /home/maximm/zephyr-esp/zephyr/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: /home/maximm/zephyr-esp/zephyr/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: /home/maximm/zephyr-esp/zephyr/build/zephyr/dts.cmake
Parsing /home/maximm/zephyr-esp/zephyr/Kconfig
Loaded configuration '/home/maximm/zephyr-esp/zephyr/build/zephyr/.config'
No change to configuration in '/home/maximm/zephyr-esp/zephyr/build/zephyr/.config'
No change to Kconfig header in '/home/maximm/zephyr-esp/zephyr/build/zephyr/include/generated/autoconf.h'
CMake Error at /home/maximm/zephyr-esp/zephyr/cmake/compiler/gcc/target.cmake:10 (message):
C compiler
/home/maximm/zephyr-sdk/xtensa//xtensa-zephyr-elf/bin/xtensa-zephyr-elf-gcc
not found - Please check your toolchain installation
Call Stack (most recent call first):
/home/maximm/zephyr-esp/zephyr/cmake/target_toolchain.cmake:57 (include)
/home/maximm/zephyr-esp/zephyr/cmake/app/boilerplate.cmake:599 (include)
/home/maximm/zephyr-esp/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
/home/maximm/zephyr-esp/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:40 (include_boilerplate)
CMakeLists.txt:5 (find_package)
-- Configuring incomplete, errors occurred!
FATAL ERROR: command exited with status 1: /usr/local/bin/cmake -DWEST_PYTHON=/home/maximm/zephyr-esp/.venv/bin/python3 -B/home/maximm/zephyr-esp/zephyr/build -S/home/maximm/zephyr-esp/zephyr/samples/basic/minimal -GNinja
