Originally published at: Low Volume, High Mix Mechanical Enclosures for IoT Projects - Golioth
We’ve been spinning up a large number of reference design hardware units to showcase a number of use cases for Golioth. This means using a number of different internal and external sensors on one unified microcontroller platform using the nRF9160 cellular SIP. Putting these in a case is a challenge since each different sensor suite calls for different openings in the enclosure. This is the story of our journey for a solution that looks great, and is available to us with low-volume order quantities.
