I’m trying to use the LightDB Stream API (as documented in Open API Docs | Golioth).
I’m able to query the list of devices for the project (/v1/projects/{projectId}/devices), but when I try to query the stream API using one of the device IDs I get the following error response:
"code": 3,
"message": "error parsing query parameters: invalid query format",
"details": []
Here’s the query:
curl -X 'GET' \
'https://api.golioth.io/v1/projects/cgnd-dev/devices/6840e324b09429a446b47f62/stream' \
-H 'accept: application/json' \
-H 'x-api-key: <redacted>'
I’m probably just missing something simple. Any idea what I’m doing wrong?
I expect that the query would return the LightDB stream data.
I’m getting the error described in the description above.
I’m using the default legacy LightDB stream pipeline.
N/A
