Originally published at: Introducing the Golioth Simulator - Golioth
At Golioth we are on a quest to improve the security, reliability, and efficiency of IoT products. Today we are launching the Golioth Simulator as part of an increasing focus on addressing the organizational challenges that come with building those products. The Simulator enables cloud engineering teams to generate data that mimics what devices deployed in the field will eventually send to Golioth, prior to the devices being ready. This eliminates bottlenecks caused by long hardware and firmware development cycles, and allows for the services that interact with device data to be developed in parallel. The Development Cycle Mismatch Building connected products is challenging for a number of reasons, but one of the most prominent is the range of engineering work that is required. This is illustrated by comparing to the development of products that are either only software, or non-networked hardware. In the former, engineering work ranges from distributed systems and backend development to frontend and graphic design. In the latter, the range may be from electrical engineering and PCB design to firmware development. IoT products essentially take those two spectra and join them. While this clearly increases the breadth of skills that are necessary for a team to possess, it also introduces a more subtle challenge: wildly different iteration cycles and development timelines. In the worst case scenario, the longest development cycle, which is typically hardware, will dictate the velocity of an entire project. A common fallacy is to compare the relative effort of software development to hardware development and conclude that the former can be delayed until the latter is in its final stages. In reality, any aspect of the engineering spectrum can derail a product. However,…
