I’d like to get all historical data for some parameters in a time period from a single device into a CSV-file for local analysis.
Following the documentation for goliothctl stream query (goliothctl stream query | Golioth), I tried setting up a query-file, but I’m not able to filter on deviceId. Filtering on another parameter works fine, but filtering on “deviceId” only gives “null” as output.
This filter works as expected:
{ “path”:“Vbatt”, “op”:“=”, “value”: 9099}
This filter gives no output, even when copying said deviceId from the response above:
{ “path”:“deviceId”, “op”:“=”, “value”: “”}
For the other stream commands like listen and get, there is the “device name”-parameter available. This does not seem to be there for query, though. I’m aware I could do this fairly easily with the REST API, but I was planning on just quickly getting this data into a file, so thought that using goliothctl would be faster ![]()
A json array of the requested data.
“null” is returned.
goliothctl CLI command.
None
