Originally published at: https://blog.golioth.io/how-to-build-your-zephyr-app-in-a-standalone-folder/
If you’re like me, you installed Zephyr and began making your own changes to the sample applications that came with the toolchain. But at some point–either for personal project repository tracking or building out a professional project–your program starts to take shape. You want to move it to its own standalone directory. It’s not immediately clear how to do that, so today we’ll dive into the nuts and bolts. (Spoiler alert: it’s pretty easy.) There be dragons in developing inside the Zephyr directory For those new to Zephyr, getting started examples like “Blinky” programs are located inside the ~/zephyrproject/zephyr/samples directory. I knew I shouldn’t just be making (and forgetting about) my own folders inside. It took my losing a few programs before I did anything about it. I wanted to reinstall the toolchain and I removed my zephyrproject directory without a thought for my poor, non-revision-controlled, early experiments with the RTOS. Don’t be me. One option is to run git init in your own subdir within the Zephyr tree. But I feel like the work I’m doing should be separate from the toolchain I’m using. So I changed the formula: I set up my own tree and told it where Zephyr is installed. Step by step By far the easiest thing to do is to copy one of the sample directories. For my fellow Linux enthusiasts this looks something like cp -r ~/zephyrproject/zephyr/samples/basic/blinky ~/. Here are the more verbose steps: Create a directory for your app Add CMakeLists.txt Create a src subdirectory and add main.c file to it That sets up the directory. You now have a folder in your home directory called blinky. Like many zephyr samples, this includes…
