Golioth returning error 500 — how should I interpret this?
During device provisioning, when the system attempts to return the PSK-IDs, Golioth responds with an error 500. I’d like to understand what this error means in this context and how to resolve it.
The provisioning process should successfully return the PSK-IDs without error.
Instead of returning the PSK-IDs, the server responds with a 500 error.
NULL
NULL
Hi @adesuwa,
Thank you for reporting this! To help us reproduce the issue, could you share:
  • The API endpoint and method you’re calling
  • The request payload (sanitized if needed)
  • The full response body, if available
Also, just to clarify, are you creating a new device with PSK credentials, or trying to fetch PSK-IDs for an existing device?
