Failure to run generate-lfs-image.py from certificate_provisioning example
I am trying to integrate certificate provisioning into the golioth reference template, such that it can use mcumgr to receive the certificate and key.
I can build and run my application just fine without the following in my CMakeLists.txt that creates a littlefs image to be flashed
add_custom_command(
    OUTPUT ${ZEPHYR_BINARY_DIR}/lfs.hex
    COMMAND ${PYTHON_EXECUTABLE}
      ${CMAKE_CURRENT_SOURCE_DIR}/generate-lfs-image.py
      --build-dir ${APPLICATION_BINARY_DIR}
add_custom_target(
    lfs ALL
    DEPENDS ${ZEPHYR_BINARY_DIR}/lfs.hex
As a result, i get this error message from my device (esp32c6 devkitm in my case):
<err> fs: mount point not found!!
Which makes sense I think, because I didn’t include those cmake instructions for building the initial littlefs image…
However, if I try to incorporate those commands above, I get the following build errors:
[1/548] Generating zephyr/lfs.hex
FAILED: [code=1] zephyr/lfs.hex C:/Users/nicol/radaon-fan-alarm-firmware/app/build/primary/zephyr/lfs.hex
C:\WINDOWS\system32\cmd.exe /C "cd /D C:\Users\nicol\radaon-fan-alarm-firmware\app\build\primary && C:\Users\nicol\.zinstaller\.venv\Scripts\python.exe C:/Users/nicol/radaon-fan-alarm-firmware/app/generate-lfs-image.py --build-dir C:/Users/nicol/radaon-fan-alarm-firmware/app/build/primary"
Traceback (most recent call last):
  File "C:\Users\nicol\radaon-fan-alarm-firmware\app\generate-lfs-image.py", line 18, in <module>
    from devicetree.edtlib import Node
ModuleNotFoundError: No module named 'devicetree'
I made sure I have all the python modules specified by Zephyr by doing the following as directed by Zephyr docs:
west zephyr-export
west packages pip --install
And I can confirm the results:
Requirement already satisfied: pyelftools>=0.29 in c:\users\nicol\.zinstaller\.venv\lib\site-packages (from -r c:\Users\nicol\radaon-fan-alarm-firmware\deps\zephyr\scripts\requirements-base.txt (line 7)) (0.32)
Requirement already satisfied: PyYAML>=6.0 in c:\users\nicol\.zinstaller\.venv\lib\site-packages (from -r c:\Users\nicol\radaon-fan-alarm-firmware\deps\zephyr\scripts\requirements-base.txt (line 11)) (6.0.3)
<REST OF PACKAGES>
Requirement already satisfied: pyparsing<4,>=2.1.0 in c:\users\nicol\.zinstaller\.venv\lib\site-packages (from rdflib->spdx-tools->-r c:\Users\nicol\radaon-fan-alarm-firmware\deps\zephyr\scripts\requirements-run-test.txt (line 22)) (3.2.5)
Can I can see that west is using the correct venv for Python3:
Environment variables and paths loaded from env.yml.
-- west build: making build dir C:\Users\nicol\radaon-fan-alarm-firmware\app\build\primary pristine
-- west build: generating a build system
Loading Zephyr default modules (Zephyr base).
-- Application: C:/Users/nicol/radaon-fan-alarm-firmware/app
-- CMake version: 4.1.2
-- Found Python3: C:/Users/nicol/.zinstaller/.venv/Scripts/python.exe (found suitable version "3.13.5", minimum required is "3.10") found components: Interpreter
-- Cache files will be written to: C:/Users/nicol/radaon-fan-alarm-firmware/deps/zephyr/.cache
-- Zephyr version: 4.2.1 (C:/Users/nicol/radaon-fan-alarm-firmware/deps/zephyr)
-- Found west (found suitable version "1.5.0", minimum required is "0.14.0")
-- Board: esp32c6_devkitc, qualifiers: esp32c6/hpcore
-- Found host-tools: zephyr 0.17.4 (C:/Users/nicol/zephyr-sdk-0.17.4)
-- Found toolchain: zephyr 0.17.4 (C:/Users/nicol/zephyr-sdk-0.17.4)
-- Found Dtc: C:/Users/nicol/.zinstaller/tools/dtc/usr/bin/dtc.exe (found suitable version "1.7.2", minimum required is "1.4.6")
-- Found BOARD.dts: C:/Users/nicol/radaon-fan-alarm-firmware/deps/zephyr/boards/espressif/esp32c6_devkitc/esp32c6_devkitc_hpcore.dts
-- Found devicetree overlay: C:/Users/nicol/radaon-fan-alarm-firmware/app/boards/esp32c6_devkitc_esp32c6_hpcore.overlay
-- Generated zephyr.dts: C:/Users/nicol/radaon-fan-alarm-firmware/app/build/primary/zephyr/zephyr.dts
-- Generated pickled edt: C:/Users/nicol/radaon-fan-alarm-firmware/app/build/primary/zephyr/edt.pickle
-- Generated devicetree_generated.h: C:/Users/nicol/radaon-fan-alarm-firmware/app/build/primary/zephyr/include/generated/zephyr/devicetree_generated.h
Are the imports inside the generate-lfs-image.py potentially outdated for Zephyr 4.2.1?
It seems that last month west-zephyr.yml in the golioth-firmware-sdk was bumped to pull v4.2.1, but the examples/zephyr/certificate_provisioning/generate-lfs-image.py was last updated 6 months ago… so perhaps these modules have changed?
Successful compilation and image generation for lfs.hex
Python import errors
Cannot use lfs since it needs an initial image to be loaded before mounting
ESP32C6 DevkitM, Golioth Reference Design Template + certificate_provisioning example
Here is my west.yml
# Copyright (c) 2022-2023 Golioth, Inc.
# SPDX-License-Identifier: Apache-2.0
manifest:
  version: 1.0
  projects:
    - name: golioth
      revision: v0.21.1
      url: https://github.com/golioth/golioth-firmware-sdk.git
      west-commands: scripts/west-commands.yml
      submodules: true
      import:
        file: west-zephyr.yml
        path-prefix: deps
        name-allowlist:
          - nrf
          - zephyr
          - cmsis_6
          - hal_nordic
          - hal_espressif
          - hal_st
          - mbedtls
          - mbedtls-nrf
          - mcuboot
          - net-tools
          - nrfxlib
          - oberon-psa-crypto
          - qcbor
          - segger
          - tfm-mcuboot
          - tinycrypt
          - trusted-firmware-m
          - zcbor
          - littlefs
    - name: zephyr-network-info
      path: deps/modules/lib/network-info
      revision: v1.2.1
      url: https://github.com/golioth/zephyr-network-info
  self:
    path: app
Here is my prj.conf:
# Enable Golioth Firmware SDK
CONFIG_GOLIOTH_FIRMWARE_SDK=y
# Golioth services used in this app
CONFIG_GOLIOTH_FW_UPDATE=y
CONFIG_GOLIOTH_LIGHTDB_STATE=y
CONFIG_LOG_BACKEND_GOLIOTH=y
CONFIG_GOLIOTH_RPC=y
CONFIG_GOLIOTH_SETTINGS=y
CONFIG_GOLIOTH_STREAM=y
# Enable common sample library
# CONFIG_GOLIOTH_SAMPLE_COMMON=y
# Enable the LittleFS file system
CONFIG_FILE_SYSTEM=y
# init before wifi credentials
CONFIG_FILE_SYSTEM_INIT_PRIORITY=89
CONFIG_FILE_SYSTEM_LITTLEFS=y
CONFIG_FILE_SYSTEM_SHELL=y
CONFIG_HEAP_MEM_POOL_SIZE=4096
# Add 256 bytes to accommodate upload command (lfs_stat overflows)
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2304
# Enable mcumgr
CONFIG_ZCBOR=y
CONFIG_MCUMGR=y
# Enable console with mcumgr pass through
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_UART_CONSOLE_MCUMGR=y
# Configure Golioth SDK dependencies
CONFIG_ZVFS_EVENTFD_MAX=14
CONFIG_ZVFS_OPEN_MAX=23
CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=1536
CONFIG_MBEDTLS_ENABLE_HEAP=y
CONFIG_MBEDTLS_HEAP_SIZE=10240
CONFIG_NETWORKING=y
CONFIG_NET_IPV4=y
CONFIG_COAP_EXTENDED_OPTIONS_LEN=y
CONFIG_COAP_EXTENDED_OPTIONS_LEN_VALUE=39
# Enable the shell mcumgr transport. This allows SMP messages to pass
# through the shell to the mgmt subsystem.
CONFIG_SHELL=y
CONFIG_SHELL_BACKEND_SERIAL=y
CONFIG_BASE64=y
CONFIG_MCUMGR_TRANSPORT_SHELL=y
# Enable file system commands
CONFIG_MCUMGR_GRP_FS=y
# Enable shell commands over SMP
CONFIG_SHELL_BACKEND_DUMMY=y
CONFIG_MCUMGR_GRP_SHELL=y
# Some mgmt command handlers require a large stack.
CONFIG_MAIN_STACK_SIZE=2048
# Enable certificate authentication.
CONFIG_GOLIOTH_AUTH_METHOD_CERT=y
# Enable `log halt` and `log go` commands
CONFIG_LOG_CMDS=y
# If runtime-settings are enabled, use the file storage-backend
CONFIG_SETTINGS_FILE=y
CONFIG_SETTINGS_FILE_PATH="/lfs1/settings"
# Application
CONFIG_NET_LOG=y
CONFIG_NET_SHELL=y
CONFIG_REBOOT=y
CONFIG_WIFI_CREDENTIALS=y
# CONFIG_WIFI_CREDENTIALS_BACKEND_PSA=y
CONFIG_WIFI_CREDENTIALS_MAX_ENTRIES=2
# Flash memory (etc.) for firmware upgrade
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_STREAM_FLASH=y
CONFIG_IMG_MANAGER=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
CONFIG_REBOOT=y
# The rest of the runtime credentials config
CONFIG_SETTINGS=y
CONFIG_SETTINGS_RUNTIME=y
# CONFIG_GOLIOTH_SAMPLE_SETTINGS_AUTOLOAD=y
# CONFIG_GOLIOTH_SAMPLE_SETTINGS_SHELL=y
# Misc.
CONFIG_JSON_LIBRARY=y
# Longer response length needed for network info
CONFIG_GOLIOTH_RPC_MAX_RESPONSE_LEN=512
CONFIG_GPIO=y
CONFIG_I2C=y
CONFIG_SENSOR=y
# Enable floating point support in printf
CONFIG_CBPRINTF_FP_SUPPORT=y
# ESP32C6-specific configurations
CONFIG_WIFI=y
CONFIG_HEAP_MEM_POOL_SIZE=49152
# CONFIG_ESP_HEAP_MEM_POOL_REGION_1_SIZE=32768 (DOESN'T EXIST)
CONFIG_NET_L2_ETHERNET=y
CONFIG_NEWLIB_LIBC=y
CONFIG_NET_DHCPV4=y
# CONFIG_ESP32_WIFI_STA_AUTO_DHCPV4=y
CONFIG_NET_L2_WIFI_SHELL=y
# CONFIG_GOLIOTH_SAMPLE_WIFI=y
# https://github.com/zephyrproject-rtos/zephyr/issues/63823
# CONFIG_POSIX_FS=n (DOESN'T EXIST)
load:0x40800000,len:0x10480
load:0x40810490,len:0x6064
SHA-256 comparison failed:
Calculated: 3e73a891cee7f0da4d1c2352b4ec0d4e60ea77500aa5bbfd5f727f75140809da
Expected: 00000000e09a0000000000000000000000000000000000000000000000000000
Attempting to boot anyway...
entry 0x40804c9e
I (69) soc_init: ESP Simple boot
I (69) soc_init: compile time Nov 22 2025 11:40:11
I (70) soc_init: chip revision: v0.2
I (70) flash_init: SPI Speed      : 80MHz
I (72) flash_init: SPI Mode       : DIO
I (76) flash_init: SPI Flash Size : 8MB
I (80) boot: DRAM: lma 0x00000020 vma 0x40800000 len 0x10480  (66688)
I (86) boot: DRAM: lma 0x000104a8 vma 0x40810490 len 0x6064   (24676)
I (92) boot: IRAM: lma 0x00016518 vma 0x00000000 len 0x9ae0   (39648)
I (98) boot: IMAP: lma 0x00020000 vma 0x42800000 len 0x24d68  (150888)
I (104) boot: IRAM: lma 0x00044d70 vma 0x00000000 len 0xb288   (45704)
I (111) boot: IMAP: lma 0x00050000 vma 0x42000000 len 0xaeec0  (716480)
I (117) boot: Image with 6 segments
I (120) boot: IROM segment: paddr=00050000h, vaddr=42000000h, size=AEEBEh (716478) map
I (128) boot: DROM segment: paddr=00020000h, vaddr=42800000h, size=24D70h (150896) map
I (147) boot: libc heap size 252 kB.
I (147) spi_flash: detected chip: gd
I (147) spi_flash: flash io: dio
{Esc}[m
{Esc}[1;32muart:~$ {Esc}[m{Esc}[8D{Esc}[J[00:00:00.005,000] {Esc}[0m<inf> wifi_init: rx ba win: 6{Esc}[0m
{Esc}[1;32muart:~$ {Esc}[m{Esc}[8D{Esc}[J[00:00:00.015,000] {Esc}[1;31m<err> fs: mount point not found!!{Esc}[0m
{Esc}[1;32muart:~$ {Esc}[m{Esc}[8D{Esc}[J[00:00:00.016,000] {Esc}[1;31m<err> fs: mount point not found!!{Esc}[0m
{Esc}[1;32muart:~$ {Esc}[m{Esc}[8D{Esc}[J[00:00:00.016,000] {Esc}[1;31m<err> wifi_credentials_backend: Initializing settings subsystem failed: -2{Esc}[0m
{Esc}[1;32muart:~$ {Esc}[m{Esc}[8D{Esc}[J[00:00:00.016,000] {Esc}[1;31m<err> wifi_credentials: Initializing WiFi credentials storage backend failed, err: -2{Esc}[0m
{Esc}[1;32muart:~$ {Esc}[m{Esc}[8D{Esc}[J*** Booting Zephyr OS build v4.2.1 ***
{Esc}[1;32muart:~$ {Esc}[m{Esc}[8D{Esc}[J*** Golioth Firmware SDK v0.21.0 ***
{Esc}[1;32muart:~$ {Esc}[m{Esc}[8D{Esc}[J[00:00:00.016,000] {Esc}[0m<dbg> golioth_rd_template: main: Start Reference Design Template sample{Esc}[0m
{Esc}[1;32muart:~$ {Esc}[m{Esc}[8D{Esc}[J[00:00:00.016,000] {Esc}[0m<inf> golioth_rd_template: Firmware version: 2.8.0{Esc}[0m
{Esc}[1;32muart:~$ {Esc}[m{Esc}[8D{Esc}[J[00:00:00.016,000] {Esc}[1;33m<wrn> golioth_rd_template: Could not stat /lfs1/credentials/crt.der, err: -2{Esc}[0m
{Esc}[1;32muart:~$ {Esc}[m{Esc}[8D{Esc}[J{Esc}[1;32muart:~$ {Esc}[m
Attempts to Resolve
Tried looking for similar build errors, but couldn’t find anything helpful on why those modules wouldn’t be included already…
Hey @nicolas,
In the Reference Design Template, Zephyr lives under the deps folder. The generate-lfs-image.py script imports devicetree and runners from the Zephyr tree (scripts/dts/python-devicetree/src and scripts/west_commands). The devicetree import error wasn’t about missing pip packages as that module comes directly from the Zephyr repo.
You can see the assumption in the script here:
WEST_TOPDIR = Path(west.configuration.west_dir()).parent
sys.path.insert(0, str(WEST_TOPDIR / 'zephyr' / 'scripts' / 'dts' / 'python-devicetree' / 'src'))
sys.path.insert(0, str(WEST_TOPDIR / 'zephyr' / 'scripts' / 'west_commands'))
from runners.core import BuildConfiguration
This assumes zephyr/ is at the repo top level. In the RD template it’s actually under deps/zephyr, so the paths don’t exist. The quick fix is to add the extra deps segment:
sys.path.insert(0, str(WEST_TOPDIR / 'deps' / 'zephyr' / 'scripts' / 'dts' / 'python-devicetree' / 'src'))
sys.path.insert(0, str(WEST_TOPDIR / 'deps' / 'zephyr' / 'scripts' / 'west_commands'))
The fs: mount point not found!! messages are a side effect of the LittleFS partition not being initialized the way this sample expects. The certificate_provisioning example relies on the CMake rule running generate-lfs-image.py to generate and flash an image that overwrites the first erase blocks of the LFS partition. LittleFS itself doesn’t require a prebuilt image, but this helper makes sure the partition starts from a known, clean state. Once the Python import issue is fixed, the mount error should go away and you can then use mcumgr to upload the cert/key files onto the filesystem.
Thank you Mark! That definitely helped!
I was running into some other issues stating it couldn’t find lfs1, but then I realized the certificate_provisioning example had some soc overlays that enabled this alias under the fstabstructure, so I did this and it worked, so i add the following to my overlay for my board file and it was able to compile:
 * Copyright (c) 2025
 * SPDX-License-Identifier: Apache-2.0
	fstab {
		compatible = "zephyr,fstab";
		lfs1: lfs1 {
			compatible = "zephyr,fstab,littlefs";
			mount-point = "/lfs1";
			partition = <&storage_partition>;
			automount;
			read-size = <16>;
			prog-size = <16>;
			cache-size = <64>;
			lookahead-size = <32>;
			block-cycles = <512>;
&wifi {
	status = "okay";
&storage_partition {
	reg = <0x00250000 0x00008000>;
Now it builds just fine and I can flash it, but I am getting some runtime errors that seem to be related to an incorrect flash size… so i need to do some digging on what value the reg should be for
As I am unsure if that is correct and how to come up with that value… (that was provided as an example for the esp32s3, but I am using the esp32c6, with 4 MB of flash)
