Originally published at: Displaying Firmware Version and Battery State with Zephyr - Golioth
We recently open-sourced the Golioth Reference Design Template that we have been using internally as the starting point for our growing library of reference designs. Out of the box, the template provides an end-to-end working firmware example showcasing all of Golioth’s key features. You can read more about what’s included in the Reference Design Template in the announcement post Open Sourcing Golioth Reference Designs and Template. The Reference Design Template firmware currently supports two boards: the Nordic nRF9160-DK and the Golioth Aludel Mini. The Aludel Mini is an internal prototyping platform designed by Golioth for rapidly building and testing proof-of-concept ideas using widely available off-the-shelf modules. The Aludel Mini integrates a nice ePaper display (Ostentus) into the enclosure, and we have been using it to display custom sensor readings specific to each reference design—for example, on the DC Power Monitor it displays current & voltage, and on the Air Quality Monitor it displays particulate matter, CO₂, and weather data. As I was working on some of the Golioth reference designs, I found myself occasionally checking the Golioth Console to confirm the firmware version was correct (for example after an OTA update) or to check the remaining battery level. The Golioth Console makes it easy to monitor values like this once the device has connected to the network, but it would be helpful to display this info immediately on the ePaper display when the device boots up (and without having to connect to the device’s UART console). Luckily, this turned out to be a really easy addition! Displaying the firmware version The Golioth Reference Design Template is built with support for the MCUboot bootloader. The firmware version is defined and later made…
