Hello there,
I am seeing some issues during OTA where the full image is being downloaded from the Golioth cloud but is not booted up by the MCUBoot.
So is pm_static.yml that is provided with the golioth reference design is necessary for the OTA to work?
These are the system settings:
- I am using NCS 2.9.0 and Golioth SDK v0.17.0
- The image is generated without sysbuild so just
app_update.binwhich is then uploaded to the console. CONFIG_BOOTLOADER_MCUBOOT=yis enabled in the prj.conf- Has all the settings defined in the template: thingy91-golioth/socs/nrf9151_ns.conf at main · golioth/thingy91-golioth · GitHub
Here is the snipped of the OTA logs from the nRF9151 device where the device does see that there is new image available, downloads it, but fails to boot the new image.
[00:08:10.913,299] <inf> golioth_fw_update: Received OTA manifest
[00:08:10.913,391] <inf> golioth_fw_update: Current version = 1.0.0, Target version = 2.0.0
[00:08:10.913,421] <inf> golioth_fw_update: State = Downloading
[00:08:11.767,761] <inf> golioth_fw_update: Received block 0/433
[00:08:11.767,822] <inf> mcuboot_util: Image index: 0, Swap type: none
[00:08:11.767,852] <inf> golioth_fw_zephyr: swap type: none
[00:08:12.321,655] <inf> golioth_fw_update: Received block 1/433
[00:08:12.616,271] <inf> vibe_monitor: Elapsed ms since last status report: 470001
[00:08:12.721,679] <inf> golioth_fw_update: Received block 2/433
[00:08:13.127,777] <inf> golioth_fw_update: Received block 3/433
[00:08:13.521,728] <inf> golioth_fw_update: Received block 4/433
[00:08:14.001,739] <inf> golioth_fw_update: Received block 5/433
[00:08:14.407,836] <inf> golioth_fw_update: Received block 6/433
[00:08:14.801,757] <inf> golioth_fw_update: Received block 7/433
[00:11:14.814,270] <inf> golioth_fw_update: Received block 432/433
[00:11:15.267,059] <inf> golioth_fw_update: Received block 433/433
[00:11:15.274,200] <inf> golioth_fw_update: Successfully downloaded 443991 bytes in 184063 ms
[00:11:15.274,230] <inf> golioth_fw_update: State = Downloaded
[00:11:15.528,869] <inf> golioth_fw_update: State = Updating
[00:11:15.847,137] <inf> golioth_fw_update: Rebooting into new image in 5 seconds
[00:11:16.847,198] <inf> golioth_fw_update: Rebooting into new image in 4 seconds
[00:11:17.847,351] <inf> golioth_fw_update: Rebooting into new image in 3 seconds
[00:11:18.847,503] <inf> golioth_fw_update: Rebooting into new image in 2 seconds
uart:~$ All pins have been configured as non-secure
Booting TF-M v2.1.1-ncs2-snapshot1
[Sec Thread] Secure image initializing!
*** Booting My Application v1.0.0-8612a1f058ed ***
*** Using nRF Connect SDK v2.9.0-7787b2649840 ***
*** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
*** Golioth Firmware SDK v0.17.0 ***
[00:00:00.607,055] <inf> golioth_settings_autoload: Initializing settings subsystem
[00:00:00.613,372] <inf> fs_nvs: 2 Sectors of 4096 bytes
[00:00:00.613,403] <inf> fs_nvs: alloc wra: 0, fa8
[00:00:00.613,403] <inf> fs_nvs: data wra: 0, b8
[00:00:00.613,464] <inf> golioth_settings_autoload: Loading settings
[00:00:00.614,288] <dbg> test: main: Starting application on nRF9151
[00:00:00.614,318] <inf> test: Firmware version: 1.0.0
[00:00:00.695,831] <inf> modem: Modem firmware version: mfw_nrf91x1_2.0.2
Has anyone seen this or am I missing something crucial that might be causing the OTA to fail.
Any directions or suggestions will be super helpful. Thank you.
