I was trying to build the Golioth reference-design-can-asset-tracker for the aludel elixir (oh yeah, that’s now supported!). I kept running into errors I didn’t understand and wanted to help light the way for others that might have similar Zephyr build errors in the future. I got an error that looked familiar but I couldn’t figure it out for a while. Do you see it?
chrisg $ ~/golioth/reference-design-can-asset-tracker west build -p -b aludel_elixir app
-- west build: making build dir /home/chrisg/golioth/reference-design-can-asset-tracker/build pristine
-- west build: generating a build system
Loading Zephyr default modules (Zephyr base).
-- Application: /home/chrisg/golioth/reference-design-can-asset-tracker/app
-- CMake version: 3.28.3
-- Found Python3: /home/chrisg/golioth/reference-design-can-asset-tracker/.venv/bin/python (found suitable version "3.12.3", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: /home/chrisg/.cache/zephyr
-- Zephyr version: 3.4.99 (/home/chrisg/golioth/reference-design-can-asset-tracker/deps/zephyr)
-- Found west (found suitable version "1.2.0", minimum required is "0.14.0")
-- Board: aludel_elixir, Revision: B
-- ZEPHYR_TOOLCHAIN_VARIANT not set, trying to locate Zephyr SDK
-- Found host-tools: zephyr 0.16.4 (/home/chrisg/zephyr-sdk-0.16.4)
-- Found toolchain: zephyr 0.16.4 (/home/chrisg/zephyr-sdk-0.16.4)
-- Found Dtc: /home/chrisg/zephyr-sdk-0.16.4/sysroots/x86_64-pokysdk-linux/usr/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6")
-- Found BOARD.dts: /home/chrisg/golioth/reference-design-can-asset-tracker/deps/modules/lib/golioth-boards/boards/arm/aludel_elixir/aludel_elixir.dts
-- Found devicetree overlay: /home/chrisg/golioth/reference-design-can-asset-tracker/deps/modules/lib/golioth-boards/boards/arm/aludel_elixir/aludel_elixir_B.overlay
-- Generated zephyr.dts: /home/chrisg/golioth/reference-design-can-asset-tracker/build/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /home/chrisg/golioth/reference-design-can-asset-tracker/build/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /home/chrisg/golioth/reference-design-can-asset-tracker/build/zephyr/dts.cmake
warning: MBEDTLS_SSL_OUT_CONTENT_LEN (defined at /home/chrisg/golioth/reference-design-can-asset-
tracker/deps/nrf/subsys/nrf_security/Kconfig.tls:298) was assigned the value '2048' but got the
value ''. Check these unsatisfied dependencies: MBEDTLS_TLS_LIBRARY (=n), NRF_SECURITY (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN and/or look up
MBEDTLS_SSL_OUT_CONTENT_LEN in the menuconfig/guiconfig interface. The Application Development
Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
might be helpful too.
warning: MBEDTLS_SSL_IN_CONTENT_LEN (defined at /home/chrisg/golioth/reference-design-can-asset-
tracker/deps/nrf/subsys/nrf_security/Kconfig.tls:305) was assigned the value '2048' but got the
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN and/or look up
MBEDTLS_SSL_IN_CONTENT_LEN in the menuconfig/guiconfig interface. The Application Development
warning: Experimental symbol NET_SOCKETS_SOCKOPT_TLS is enabled.
warning: Experimental symbol NET_SOCKETS_ENABLE_DTLS is enabled.
Parsing /home/chrisg/golioth/reference-design-can-asset-tracker/app/Kconfig
Loaded configuration '/home/chrisg/golioth/reference-design-can-asset-tracker/deps/modules/lib/golioth-boards/boards/arm/aludel_elixir/aludel_elixir_defconfig'
Merged configuration '/home/chrisg/golioth/reference-design-can-asset-tracker/app/prj.conf'
Configuration saved to '/home/chrisg/golioth/reference-design-can-asset-tracker/build/zephyr/.config'
Kconfig header saved to '/home/chrisg/golioth/reference-design-can-asset-tracker/build/zephyr/include/generated/autoconf.h'
-- Found GnuLd: /home/chrisg/zephyr-sdk-0.16.4/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
-- The C compiler identification is GNU 12.2.0
-- The CXX compiler identification is GNU 12.2.0
-- The ASM compiler identification is GNU
-- Found assembler: /home/chrisg/zephyr-sdk-0.16.4/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
CMake Warning at /home/chrisg/golioth/reference-design-can-asset-tracker/deps/modules/lib/golioth-firmware-sdk/examples/zephyr/common/CMakeLists.txt:10 (message):
WARNING: Using CONFIG_GOLIOTH_SAMPLE_COMMON=y with external application
code. This option is supposed to be used only from projects in
-- Configuring done (2.5s)
-- Generating done (0.1s)
-- Build files have been written to: /home/chrisg/golioth/reference-design-can-asset-tracker/build
-- west build: building application
[1/378] Preparing syscall dependency handling
[3/378] Generating include/generated/version.h
-- Zephyr version: 3.4.99 (/home/chrisg/golioth/reference-design-can-asset-tracker/deps/zephyr), build: v3.4.99-ncs1-2
[28/378] Building C object CMakeFiles/app.dir/src/main.c.obj
FAILED: CMakeFiles/app.dir/src/main.c.obj
ccache /home/chrisg/zephyr-sdk-0.16.4/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DKERNEL -DMBEDTLS_CONFIG_FILE=\"config-tls-generic.h\" -DNRF9160_XXAA -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DPICOLIBC_INTEGER_PRINTF_SCANF -DZCBOR_VARIANCE -DZCBOR_VERSION_MAJOR=0 -DZCBOR_VERSION_MINOR=7 -D_FORTIFY_SOURCE=1 -D_POSIX_C_SOURCE=200809 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -Dtimegm=mktime -I/home/chrisg/golioth/reference-design-can-asset-tracker/app/src/lib/inc -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/zephyr/include -I/home/chrisg/golioth/reference-design-can-asset-tracker/build/zephyr/include/generated -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/zephyr/soc/arm/nordic_nrf/nrf91 -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/zephyr/lib/posix/getopt/. -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/zephyr/soc/arm/nordic_nrf/common/. -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/zephyr/subsys/net/lib/coap/. -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/zephyr/subsys/net/lib/sockets/. -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/zephyr/subsys/net/lib/tls_credentials/. -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/zephyr/subsys/net/lib/dns/. -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/zephyr/subsys/settings/include -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/modules/lib/golioth-firmware-sdk/port/zephyr/include -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/modules/lib/golioth-firmware-sdk/port/zephyr/../../include -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/modules/lib/golioth-firmware-sdk/examples/zephyr/common/include -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/modules/lib/golioth-firmware-sdk/port/zephyr/include_random -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/modules/lib/network-info/include -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/nrf/include -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/nrf/tests/include -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/modules/hal/cmsis/CMSIS/Core/Include -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/zephyr/modules/cmsis/. -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/modules/hal/nordic/nrfx -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/modules/hal/nordic/nrfx/drivers/include -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/modules/hal/nordic/nrfx/mdk -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/zephyr/modules/hal_nordic/nrfx/. -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/modules/lib/zcbor/include -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/modules/crypto/mbedtls/include -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/zephyr/modules/mbedtls/configs -I/home/chrisg/golioth/reference-design-can-asset-tracker/deps/zephyr/modules/mbedtls/include -isystem /home/chrisg/golioth/reference-design-can-asset-tracker/deps/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros /home/chrisg/golioth/reference-design-can-asset-tracker/build/zephyr/include/generated/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/home/chrisg/zephyr-sdk-0.16.4/arm-zephyr-eabi/arm-zephyr-eabi -imacros /home/chrisg/golioth/reference-design-can-asset-tracker/deps/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/home/chrisg/golioth/reference-design-can-asset-tracker/app=CMAKE_SOURCE_DIR -fmacro-prefix-map=/home/chrisg/golioth/reference-design-can-asset-tracker/deps/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/home/chrisg/golioth/reference-design-can-asset-tracker=WEST_TOPDIR -ffunction-sections -fdata-sections --specs=picolibc.specs -D_POSIX_THREADS -std=c99 -MD -MT CMakeFiles/app.dir/src/main.c.obj -MF CMakeFiles/app.dir/src/main.c.obj.d -o CMakeFiles/app.dir/src/main.c.obj -c /home/chrisg/golioth/reference-design-can-asset-tracker/app/src/main.c
/home/chrisg/golioth/reference-design-can-asset-tracker/app/src/main.c:37:39: error: 'CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION' undeclared here (not in a function)
37 | static const char *_current_version = CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION;
[ ... errors continue for many pages]
I will “solve” the answer below for my own edification and also to help others in the future.
