Originally published at: Automatically Detecting Boards for Hardware-in-the-Loop (HIL) Testing - Golioth
Golioth is an IoT company that supports as much custom hardware as possible: a multitude of microcontrollers and many different connection types. This presents a challenge when testing on real hardware. We developed tooling that tests the Golioth Firmware SDK on actual boards. Known as Hardware-in-the-Loop (HIL) testing, it’s an important part of our CI strategy. Our latest development is automatically detecting boards connected to our CI machines; these can recognize what type of hardware is attached to each self-hosted test runner. In a nutshell, you plug in the board to USB and run a workflow to figure out what you just plugged it. Let’s take a look at how we did that, and why it’s necessary. Goals and Challenges of Hardware Testing So the fundamental goals here are: Run tests on actual hardware Make the number of tests scalable Make the number of hardware types scalable If we were running all of our firmware tests manually, we’d be fine on goal #1. But when scaling and repeatability comes into play, we start to look at automation. In particular, we look at making it easy to create more of the self-hosted runners (the computers running the automated test programs). Adding a new board to one of those runners is no small task. If you build a self-hosted runner today, then next week add two new hardware variations that need testing, how will the runner know how to interface with those boards? Frequent readers of the Golioth blog will remember that we already set up self-hosted runners, so go back and look the first post and second post in this series. Those articles detail how we are using GitHub’s self-hosted runner…
