Adding PWM sound in Zephyr
Originally published at: Adding PWM sound in Zephyr - Golioth
It’s easier than ever to create a system that plays audio. Greeting cards do it, watches do it, just about any consumer system is capable of playing sound. Yes, the quality is variable, but that abides by the old maxim of, “you get what you pay for”. So what happens if we have a very low cost piezoelectric element (shortened to piezo for the rest of this article), an NPN transistor, and a microcontroller with PWM capabilities…can we make that do anything fun from Zephyr? It turns out, yes, we can. Let’s take a look. Simplicity The hardware components on the schematic are pretty bare bones. The output pin from the microcontroller drives an NPN transistor, which then draws current down through a piezo. If we vary the on-off nature through the piezo, we’ll get a tone that matches the frequency of the AC waveform we are using. Using a frequency of 440 Hz should result in an A4 tone. In fact, it does! Click to download Thingy91 schematic files from Nordic Semiconductor The on-off nature of a PWM signal creates a square wave. This creates harmonics that produce a a recognizable, if not harsh tone. Songs with tonality like this are sometimes referred to as “chiptune“, because of its association with early video games and their limited capabilities to generate more complex waveforms. Personally, I have a lot of positive associations with this style of sound and music, since I grew up with early games that employed this type of music; it has also developed as a musical subgenre. But for today’s article, all that’s necessary to know is that we will be generating simple square wave tones, which…
