Adding Golioth to an existing nRF Project
Hey, has anybody tried adding Golioth to an existing project on NRF Connect SDK? If so, Id have a couple of questions:
  1. Can Golioth run on a Non-Secure build of my system (nrf9160, using official DK)? I keep getting "undefined reference to soc_secure_mem_read if do try to run the project on NS. Unfortunately, I cant use the modem in a Secure build so im a bit cornered…
  2. Can Golioth be simply added to the project folder, say as an external library, then built with CMakeLists? The documentation in setting it up is a bit vague, so Im having troubles with understanding it…
Sorry if my questions are stupid, as Im an absolute newbie to NRF and Golioth… P.S. regarding question 2, what ive tried:
  • adding Golioth repo to the nrf west.yml, but then i would get linking errors as the source files would not find headers
  • as described in github, initializing Golioth with west in my project directory, what then resulted in a hefty amount of linker errors
  • (currently) Initializing Golioth with west and adding my project files into the new Golioth folder. Compilation stops due to some modules requiring access blocked by Non-Secure build cfg. What is interesting, as Nrf9160 Feather, showcasing Golioth example also uses Non-Secure build cfg, and everything apparenly works for them. (maybe im doing something completely wrong on the way here)
Hey @biurokratas,
All of our Zephyr/Nordic samples for the nRF9160 DK are built as a Non-Secure Zephyr applications. As you pointed out, in order to use the modem, the application for the nRF9160 DK must be built as _ns.
  1. Can Golioth be simply added to the project folder, say as an external library, then built with CMakeLists? The documentation in setting it up is a bit vague, so Im having troubles with understanding it…
Yes, it can; we use that approach with ESP-IDF examples. For reference, see the CMake files in hello sample.
From your post, it seems you haven’t set up the build environment correctly. Adding Golioth Firmware SDK to an existing Zephyr West project is described here. Running the west update command is mandatory in order to clone the newly added Golioth module.
We are big proponents of manifest files, and having a separate environment for each project with a different Zephyr version makes life a whole lot easier. In order to learn more about manifest files, I would suggest you take a look at this blog post.
A good starting point for learning Zephyr and Golioth would be to use the Golioth Reference Design Template, that you can build for the nRF9160 DK.
Good day to you @marko,
Thank you for a comprehensive response! Seems like I have some more homework to do :slight_smile:. Though I would still want to point out some things I have encountered trying to set up the environment intuitively.
This is (supposedly) the correct way:
Following NCS (NRF Connect SDK) documentation, I created a customized workspace, where, according to Golioth documentation I appended the west file like so:
manifest:
  self:
    path: application
  remotes:
    - name: nrf
      url-base: https://github.com/nrfconnect
  projects:
    - name: golioth
      path: external/modules/lib/golioth-firmware-sdk
      revision: main
      url: https://github.com/golioth/golioth-firmware-sdk.git
      submodules: true
    - name: sdk-nrf
      remote: nrf
      path: nrf
      revision: v2.5.99-dev1
      import:
        path-prefix: external
      clone-depth: 1
After running west update, all of the NCS alongside Golioth was placed as external resources in my project file successfully. In this case, when building the application, I would get the following:
warning: attempt to assign the value β€˜y’ to the undefined symbol GOLIOTH
What indicates that something is not linking properly.
After such failure, I have proceeded to try different approaches (that are incorrect):
  1. Initialize Golioth directly in a NCS non-custom workspace (in the custom one, I cannot re-initialize west), as per this indication. This resulted in previously stated warning disappearing, but linker errors appearing.
  1. Initialize Golioth SDK for NCS first, then copy my project files over. This resulted in linker errors disappearing, though the project could not compile due to configuration conflicts (Golioth requiring access to secure space, modem requiring the build to be non-secure).
So disregarding the incorrect approaches, I am still confused why doesn’t it link in the (supposedly) correct one?
Can you add Golioth as a module to the west manifest file for the nRF Connect SDK?
It’s located in the nrf/ folder:
<home>/
β”œβ”€β”€β”€ toolchains/
β”‚  └─── <toolchain-installation>
└─── <west-workspace>/
   β”œβ”€β”€β”€ .west/
   β”œβ”€β”€β”€ bootloader/
   β”œβ”€β”€β”€ modules/
   β”œβ”€β”€β”€ nrf/
   β”œβ”€β”€β”€ nrfxlib/
   β”œβ”€β”€β”€ zephyr/
Your manifest file should look like this:
# The west manifest file (west.yml) for the nRF Connect SDK (NCS).
# The per-workspace west configuration file, ncs/.west/config,
# specifies the location of this manifest file like this:
#     [manifest]
#     path = nrf
# See the west documentation for more information:
# https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/guides/west/index.html
manifest:
  version: "0.13"
  # "remotes" is a list of locations where git repositories are cloned
  # and fetched from.
  remotes:
    # nRF Connect SDK GitHub organization.
    # NCS repositories are hosted here.
    - name: ncs
    # Third-party repository sources:
    - name: zephyrproject
      url-base: https://github.com/zephyrproject-rtos
    - name: throwtheswitch
      url-base: https://github.com/ThrowTheSwitch
    - name: armmbed
      url-base: https://github.com/ARMmbed
    - name: nordicsemi
      url-base: https://github.com/NordicSemiconductor
    - name: dragoon
      url-base: https://projecttools.nordicsemi.no/bitbucket/scm/drgn
    - name: memfault
      url-base: https://github.com/memfault
    - name: ant-nrfconnect
      url-base: https://github.com/ant-nrfconnect
    - name: babblesim
      url-base: https://github.com/BabbleSim
    - name: bosch
      url-base: https://github.com/boschsensortec
  # If not otherwise specified, the projects below should be obtained
  # from the ncs remote.
  defaults:
    remote: ncs
  group-filter: [-homekit, -nrf-802154, -dragoon, -find-my, -ant, -babblesim, -sidewalk, -bsec]
  # "projects" is a list of git repositories which make up the NCS
  # source code.
  # For 'userdata' fields in the projects area, please refer to:
  # https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/dm_code_base.html
  projects:
    # Golioth repository.
    - name: golioth
      revision: main
      submodules: true
    # The Zephyr RTOS fork in the NCS, along with the subset of its
    # modules which NCS imports directly.
    # https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/introduction/index.html
    # https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/guides/modules.html
    - name: zephyr
      repo-path: sdk-zephyr
      revision: v3.4.99-ncs1-2
      import:
Afterward, can you run west update from the <west-workspace> folder and try to build the hello sample located at modules/lib/golioth-firmware-sdk/examples/zephyr/hello ?
Also, are you using nRF Connect SDK v2.5.2? That is the latest version verified by our Continuous Integration system.
It appears that the issue was in versioning, as I was using NCS v2.5.99-dev1 and previously I would use golioth-zephyr-sdk instead of golioth-firmware-sdk, where I absolutely forgot to redefine my CONFIG_GOLIOTH=y to CONFIG_GOLIOTH_FIRMWARE_SDK=y in the config file.
As of now, NCS v2.5.2 with `` golioth-firmware-sdk works perfectly!
Thank you very much for all of the help!
