yes it’s start with in a frame with modem device init on startup.
i have a delay around 4 seconds after startup than the thread run.
the problem occure on weak connection around -80db to 90db.
I’m not understanding why i see the device getting this error while getting in the backend this infor
the modem is fully attached and i see it online in the 1nce console.
dns is also working and i have a ip.
so seams it’s really on the thread
#include <zephyr/kernel.h>
#include "temp.h"
#include "settings.h"
#include "config.h"
#include <zephyr/net/socket.h>
#include <zephyr/net/net_if.h>
#include <zephyr/net/dns_resolve.h>
#include "app_networking.h"
#include "app_golioth.h"
#include <golioth/client.h>
#include <golioth/fw_update.h>
#include <golioth/stream.h>
#include <app_version.h>
#include <zephyr/pm/device.h>
#include <zephyr/pm/device_runtime.h>
#include <zephyr/drivers/uart.h>
#include "file_manager.h"
#include <zephyr/drivers/cellular.h>
#include "saadc.h"
#include "utils.h"
#include "nb_payload.h"
#include <zephyr/logging/log.h>
LOG_MODULE_REGISTER(lte_data_thread,LOG_LEVEL_INF);
#define THREAD_PRIORITY_DATA 4
#define THREAD_STACKSIZE_DATA 9216
#define THREAD_START_DELAY 4000
#define CONNECTION_TIMEOUT 20 * 1000
#define MAX_WAIT_MS 5000
#define POLL_INTERVAL_MS 200
K_SEM_DEFINE(lte_send_sem, 0, 1); // Initial count 0, max count 1
// K_SEM_DEFINE(lte_shell_wait, 0, 1);
K_SEM_DEFINE(connected, 0, 1); // check if golioth is connected or not
const struct device *modem = DEVICE_DT_GET(DT_ALIAS(modem));
static const struct device *uart_dev = DEVICE_DT_GET(DT_NODELABEL(uart1));
extern bool _force_send_status;
#include "app_sntp.h"
static void on_client_event(struct golioth_client *client,
enum golioth_client_event event,
void *arg)
bool is_connected = (event == GOLIOTH_CLIENT_EVENT_CONNECTED);
LOG_INF("Golioth client %s", is_connected ? "connected" : "disconnected");
if (is_connected)
k_sem_give(&connected);
else
pm_device_action_run(modem, PM_DEVICE_ACTION_SUSPEND);
pm_device_action_run(uart_dev, PM_DEVICE_ACTION_SUSPEND);
K_SEM_DEFINE(fw_update_complete, 0, 1);
static bool _is_update_in_progress = false;
static void on_fw_update_state_change(enum golioth_ota_state state,
enum golioth_ota_reason reason,
void *user_arg)
LOG_INF("Firmware update state changed to: %d, reason: %d", state, reason);
switch (state)
case GOLIOTH_OTA_STATE_IDLE:
_is_update_in_progress = false; // No update in progress
LOG_INF("Firmware update is idle.");
break;
case GOLIOTH_OTA_STATE_DOWNLOADING:
_is_update_in_progress = true; // Update started
LOG_INF("Firmware update downloading...");
break;
case GOLIOTH_OTA_STATE_DOWNLOADED:
_is_update_in_progress = true; // Update downloaded, ready to apply
LOG_INF("Firmware update downloaded.");
break;
case GOLIOTH_OTA_STATE_UPDATING:
_is_update_in_progress = true; // Firmware is being applied
LOG_INF("Firmware is being applied...");
if (reason == GOLIOTH_OTA_REASON_FIRMWARE_UPDATED_SUCCESSFULLY)
k_sem_give(&fw_update_complete); // Release semaphore
else if (reason == GOLIOTH_OTA_REASON_FIRMWARE_UPDATE_FAILED)
LOG_ERR("Firmware update failed.");
break;
default:
break;
static void stop_client_if_update_complete(struct golioth_client *client)
uint32_t waited = 0;
while (golioth_client_num_items_in_request_queue(client) > 0 && waited < MAX_WAIT_MS)
LOG_INF("Waiting for Golioth request queue to empty...");
k_sleep(K_MSEC(POLL_INTERVAL_MS));
waited += POLL_INTERVAL_MS;
if (waited >= MAX_WAIT_MS)
LOG_WRN("Timeout waiting for Golioth queue to empty");
if (!_is_update_in_progress)
// No update is in progress, skip waiting for the semaphore
LOG_INF("No firmware update in progress, stopping the client.");
golioth_client_stop(client);
return;
// If update is in progress, wait for the semaphore
LOG_INF("Waiting for firmware update to complete...");
k_sem_take(&fw_update_complete, K_FOREVER);
// Now it's safe to stop the client
LOG_INF("Firmware update complete, stopping the client.");
// #include <zephyr/drivers/modem/simcom-sim7080.h>
#define MAX_RETRIES 5
#define RETRY_TIMEOUT_MS 90000 // 90 seconds per try (can also be 60000 for 60s)
#define BACKOFF_SLEEP_MS (60 * 60 * 1000) // 1 hour sleep on failure
#define SLEEP_BETTWEEN_TIMOUTS 120000 // 2 minutes sleep between retries
static bool wait_for_connection(void)
for (int retry = 1; retry <= MAX_RETRIES; retry++)
LOG_INF("Attempt %d to connect to Golioth...", retry);
if (retry > 1)
pm_device_action_run(uart_dev, PM_DEVICE_ACTION_RESUME); // EALREADY
pm_device_action_run(modem, PM_DEVICE_ACTION_RESUME); // EALREADY
int wait = k_sem_take(&connected, K_MSEC(RETRY_TIMEOUT_MS));
if (wait == 0)
LOG_INF("Connected to Golioth");
return true;
k_sleep(K_MSEC(SLEEP_BETTWEEN_TIMOUTS));
LOG_WRN("Retry %d/%d timed out after %d seconds",
retry, MAX_RETRIES, RETRY_TIMEOUT_MS / 1000);
LOG_ERR("Failed to connect after %d attempts.", MAX_RETRIES);
return false;
static void data_thread(void)
LOG_INF("data_thread started");
static int64_t last_time_sensor_readings_send = 0;
// net_connect();
if (!app_net_connect())
LOG_ERR("No IP connectivity — fallback");
return;
if (strlen(lte_cfg.client_psk_id) == 0 || strlen(lte_cfg.client_psk) == 0) {
LOG_INF("PSK credentials not set, skipping...");
return;
struct golioth_client_config my_client_config = {
.credentials =
.auth_type = GOLIOTH_TLS_AUTH_TYPE_PSK,
.psk =
.psk_id = lte_cfg.client_psk_id,
.psk_id_len = strlen(lte_cfg.client_psk_id),
.psk = lte_cfg.client_psk,
.psk_len = strlen(lte_cfg.client_psk),
LOG_INF("PSK ID: %s", lte_cfg.client_psk_id);
LOG_INF("PSK: %s", lte_cfg.client_psk);
LOG_INF("PSK ID len: %d", strlen(lte_cfg.client_psk_id));
LOG_INF("PSK len: %d", strlen(lte_cfg.client_psk));
int ret = sync_date();
if (ret < 0)
LOG_ERR("Failed to sync date/time: %d", ret);
struct golioth_client *client = golioth_client_create(&my_client_config);
golioth_client_register_event_callback(client, on_client_event, NULL);
// TODO: disabled, becaus we don't get the right finish command
// golioth_fw_update_init(client, _current_version);
// golioth_fw_update_register_state_change_callback(on_fw_update_state_change, NULL);
app_settings_register(client);
print_cellular_info(modem);
check_all_registrations(modem);
// do_ipv4_lookup();
if (!wait_for_connection()) // hard version // k_sem_take(&connected, K_FOREVER);
LOG_ERR("Failed to connect to Golioth");
return; // Exit the thread if connection fails multiple times
// send status data
int err = send_status_payload(modem, client, STATUS_FIRST_BOOT, 0);
if (err != 0)
LOG_ERR("Failed to send status payload");
stop_client_if_update_complete(client);
while (1)
int reason = k_sem_take(<e_send_sem, K_MSEC(lte_cfg.send_record_data_interval_s * 1000)); // we wake up every hour and check if something there to send
uint8_t status = STATUS_OK;
if (reason == 0 || _force_send_status)
LOG_INF("Semaphore triggered or force status. Sending data.");
status = STATUS_MAINTENANCE; // TODO marke the send type!
else if (reason == -EAGAIN)
LOG_INF("Semaphore Timeout reached. Sending data.");
else
LOG_ERR("Semaphore take failed with error %d", reason);
continue; // Retry if there was an error
// check if we have records to send
int total_records_in_bytes = get_file_size(REC_FILE_PATH); // Pass 0 to read all available records
if (total_records_in_bytes <= 0 && status == STATUS_OK)
LOG_INF("No records to send");
continue;
LOG_ERR("No IP connectivity — next time");
continue;
//sync time
if (ret < 0)
int start_err = golioth_client_start(client);
if (start_err != 0)
LOG_ERR("Failed to start Golioth client: %d", start_err);
continue;
LOG_INF("Golioth client started");
// int connectionReason = k_sem_take(&connected, CONNECTION_TIMEOUT);
if (!golioth_client_wait_for_connect(client, 3000))
continue;
// send status data
int err = send_status_payload(modem, client, status, 0); // TODO: check error register!
if (err != 0)
err = stream_file_to_golioth(client, "/record", REC_FILE_PATH);
if (err != 0)
LOG_ERR("Failed streaming record data. %d", err);
else
LOG_INF("Sent %d bytes of records ", total_records_in_bytes);
file_manager_delete(REC_FILE_PATH);
print_counter(&counter);
counter_reset(&counter, false);
// !!! we don't send data if the send_adc_data_interval_s is 0!!!
int64_t now = k_uptime_get();
if (lte_cfg.send_adc_data_interval_s != 0 && (now - last_time_sensor_readings_send) >= lte_cfg.send_adc_data_interval_s * 1000)
LOG_INF("Sending sensor data");
err = stream_file_to_golioth(client, "/sensor", ADC_FILE_PATH);
if (err != 0)
LOG_ERR("Failed streaming sensor data. %d", err);
GLTH_LOGE(TAG, "Failed streaming sensor data. %d", err);
else
LOG_INF("Sent %d records", total_records_in_bytes);
file_manager_delete(ADC_FILE_PATH); // TODO: check if we need a extra check or discuss if this is good ?
last_time_sensor_readings_send = now;
// check if we need to send data on next online
if (lte_cfg.send_adc_data_interval_s == 1)
LOG_INF("Sending sensor data on next online");
reset_send_adc_data_next_online();
// TODO: kConfig for not using modem api
K_THREAD_DEFINE(data_tid, THREAD_STACKSIZE_DATA, data_thread, NULL, NULL, NULL, THREAD_PRIORITY_DATA, 0, THREAD_START_DELAY);
*** Booting My Application v0.0.6-stable-480f0d9f11a9 ***
*** Using nRF Connect SDK v2.9.0-7787b2649840 ***
*** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
*** Golioth Firmware SDK v0.17.0-5-g7594c7ad6c5b ***
[00:00:00.060,791] <inf> edge_app: GPIO 2V4 already set 0xFFFFFFFA
[00:00:00.060,791] <inf> edge_app: Starting application...
[00:00:00.060,821] <inf> edge_app: Build time: Mar 27 2025 13:41:24
[00:00:00.060,852] <inf> edge_app: Version: 0.0.6
[00:00:00.060,852] <inf> edge_app: SerialNo db185061
[00:00:00.063,964] <inf> fs_nvs: 4 Sectors of 4096 bytes
[00:00:00.063,995] <inf> fs_nvs: alloc wra: 0, d38
[00:00:00.063,995] <inf> fs_nvs: data wra: 0, a4c
[00:00:00.076,202] <inf> edge_app: SIMCOM module initalised
[00:00:00.076,232] <inf> edge_app: Golioth psk_id:xxx@xxx
[00:00:00.076,263] <inf> edge_app: Golioth psk:xxx
[00:00:00.076,293] <inf> led0m
[00:00:04.060,821] <inf> lte_data_thread: data_thread started
[00:00:04.060,913] <inf> app_networking: Bringing up network interface
[00:00:04.061,004] <inf> app_networking: Waiting to obtain IP address
[00:00:24.100,524] <inf> app_networking: Network event received
[00:00:25.100,677] <inf> lte_data_thread: PSK ID: xxx@txxx
[00:00:25.100,708] <inf> lte_data_thread: PSK: xxxx
[00:00:25.100,738] <inf> lte_data_thread: PSK ID len: 30
[00:00:25.100,738] <inf> lte_data_thread: PSK len: 32
[00:00:25.146,942] <inf> app_networking: RSSI -79
[00:00:25.147,003] <inf> app_networking: IMEI: 860016049954113
[00:00:25.147,033] <inf> app_networking: Technology 4: Registration status = Registered (Roaming)
[00:00:25.147,064] <inf> app_networking: Technology 7: Registration status = Registered (Roaming)
[00:00:25.147,125] <inf> app_networking: Technology 0: Registration status = Not Registered
[00:00:25.147,155] <inf> app_networking: Technology 2: Registration status = Registered (Roaming)
[00:00:25.147,155] <inf> lte_data_thread: Attempt 1 to connect to Golioth...
[00:00:28.738,281] <err> golioth_coap_client_zephyr: Failed to connect to socket: -11
[00:00:28.739,318] <err> golioth_coap_client_zephyr: Failed to connect: -11
[00:00:28.739,318] <wrn> golioth_coap_client_zephyr: Failed to connect: -11
[00:00:37.499,023] <err> golioth_coap_client_zephyr: Failed to connect to socket: -11
[00:00:37.500,061] <err> golioth_coap_client_zephyr: Failed to connect: -11
[00:00:37.500,061] <wrn> golioth_coap_client_zephyr: Failed to connect: -11
[00:00:46.372,985] <err> golioth_coap_client_zephyr: Failed to connect to socket: -11
[00:00:46.373,840] <err> golioth_coap_client_zephyr: Failed to connect: -11
[00:00:46.373,840] <wrn> golioth_coap_client_zephyr: Failed to connect: -11
[00:00:54.628,051] <err> golioth_coap_client_zephyr: Failed to connect to socket: -11
[00:00:54.629,058] <err> golioth_coap_client_zephyr: Failed to connect: -11
[00:00:54.629,089] <wrn> golioth_coap_client_zephyr: Failed to connect: -11
[00:01:03.049,041] <err> golioth_coap_client_zephyr: Failed to connect to socket: -11
[00:01:03.050,048] <err> golioth_coap_client_zephyr: Failed to connect: -11
[00:01:03.050,048] <wrn> golioth_coap_client_zephyr: Failed to connect: -11
[00:01:11.333,129] <err> golioth_coap_client_zephyr: Failed to connect to socket: -11
[00:01:11.333,953] <err> golioth_coap_client_zephyr: Failed to connect: -11
[00:01:11.333,953] <wrn> golioth_coap_client_zephyr: Failed to connect: -11
[00:01:19.699,035] <err> golioth_coap_client_zephyr: Failed to connect to socket: -11
[00:01:19.700,073] <err> golioth_coap_client_zephyr: Failed to connect: -11
[00:01:19.700,073] <wrn> golioth_coap_client_zephyr: Failed to connect: -11
BR
