Hello!
Trying to filter on “tags” in e.g. Logs or Device view seems to work for some of our tags, but not other tags.
i.e. the device looks like it has the tag on it, but not possible to find it in the list.
Is there a solution to fix this?
POST https://api.golioth.io/v1/projects/PROJECT_ID/tags
X-API-Key: YOUR_API_KEY
Content-Type: application/json
{“name”: “example-tag”}
then
PATCH https://api.golioth.io/v1/projects/PROJECT_ID/devices/DEVICE_ID
{“addTagId”: [“TAG_ID”]}
Can filter on the tag in logs and devices view
the dropdown shows “no data” when typing the first letters of the tag
difficult to group logs and understand patterns
Golioth web console: Devices and Logs views.
Tags are created and assigned to devices through the Golioth
Management REST API from a server-side application using JSON requests.
Some tags appear on devices but cannot be found in the console’s
tag-filter dropdown. Other tags work correctly.
The tag-filter dropdown displays “no data” when entering the first
letters of an affected tag. No additional error output collected yet.
